Date/Time: Sat, 04 May 2024 18:40:43 +0000
Chart settings
View Count: 1059
[2014-02-20 20:50:20] |
User72642 - Posts: 6 |
Hi there, I have couple of issues, please help 1 - i'm having trouble creating a 5 min chart with separate Volume Profiles for regular trading hours and for overnight trading hours. 2 - I want to create a market profile chart displaying separate profiles for RTH and overnight hours please help sending the settings i need to use in order to create these charts. Thanks |
[2014-02-20 21:20:49] |
ganz - Posts: 1048 |
User72642 1. see Use Separate Profile for Evening Session http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings 2. see New Period At Day Session Start When Using Evening Session (1 Day Period Only) http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TPOProfileSettings |
[2014-02-20 21:32:25] |
thanks ganz, I have been trying all those settings, and i can't seem to get what i want. i must be doing something wrong and really don't know how to set this up properly, also somehow it is very confusing and frustrating for me Could you please post a picture with the exact settings in order to get those charts? thanks |
[2014-02-20 21:36:47] |
User72642 are you able to share some exmpls of charts you are looking for? |
[2014-02-20 21:57:57] |
User72642 the chartbook is attached place it into X:\SierraChart\Data\ File-->Open Chartbook F5-->Symbol-->Find |
nb_exmpl.cht - Attached On 2014-02-20 21:57:45 UTC - Size: 123.58 KB - 325 views |
[2014-02-21 03:23:05] |
We need to work on documentation for this. We will try to have this ready tomorrow.
[2014-03-30 03:56:43] |
Here is the documentation for this: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#DayEveningSeparateProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
