Date/Time: Mon, 29 Apr 2024 02:02:27 +0000
Denali Historical Data
View Count: 698
[2021-01-13 04:49:12] |
User279754 - Posts: 38 |
Is there any way to obtain Denali data further back than 10 years? I develop automated systems, so back testing is crucial and any additional historical data is highly valuable to me. I would be willing to pay a premium if necessary to obtain access to the oldest data available. Thank you. |
[2021-01-13 06:42:33] |
For what symbols?
[2021-01-13 06:45:04] |
It would be for NQ, ES, YM, RTY, and GC. I would also need VIX data, which I also pay for separately. The VIX data also only goes back about 10 years.
Date Time Of Last Edit: 2021-01-13 06:45:30
[2021-01-14 01:35:06] |
We checked these symbols: NQ, ES, There is data back to June 2008. And that is accessible now. We cannot provide any further data. You need to find another source and you can import it: Exporting and Importing Intraday Data Files For the other symbols, use the month code and year in the symbol, going back to the month and year that you want to see if data is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-14 01:36:13
[2021-01-14 14:58:06] |
Would you be so kind as to check $VIX as well? I realize that's not the Denali feed specifically, but that one is critical to me and if I could get that data back to 2008 as well, it would be an enormous help. $VIX currently goes back to about May 2010, but I believe a year or two ago you used to have it back to 2009 and at some point it got truncated. Thank you so much. |
[2021-01-15 10:30:04] |
You are able to check this yourself. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
