Date/Time: Mon, 06 May 2024 05:04:57 +0000
price plans
View Count: 431
[2021-01-12 22:27:57] |
Timothy Hartnett - Posts: 5 |
Hi, Im not sure how the pricing works or what I need. I just want the charts for live market replay of DAX intraday data. Is the basic package enough or do I need to buy data as well? Thanks.
[2021-01-12 22:41:33] |
John - SC Support - Posts: 31379 |
First of all, refer to the following information for the differences in the Service Packages: Description of Service Packages and Pricing: Packages If you are really just looking to replay data and will not be needing any of the advanced services (Numbers Bars, TPO, etc.), then you would just need Package 3. If you do not need live data or Market Depth information, then you would not need to purchase any data. You can get historical data for the DAX at no extra charge, which will be at least 20 minutes delayed and only update every 20 minutes or more. Refer to the information here: Sierra Chart Historical Data Service If you do need Real-Time data, then you would want to use the Sierra Chart Exchange Data Feed and activate the EUREX exchange. Refer to the information here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
