Date/Time: Fri, 03 May 2024 20:00:48 +0000
flatten button
View Count: 468
[2021-01-12 19:59:47] |
User498170 - Posts: 2 |
Hello, i have a problem with the flatten button. When I want to flat the position and I press the corresponding button it don't exit the position but cancels stop and TP, and let the position run. I must then press a second time for exit position. Is there a setting to exit the full position? thank you in advance cordially |
[2021-01-12 20:06:10] |
John - SC Support - Posts: 31360 |
Refer to the information here: Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
