Date/Time: Wed, 04 Nov 2026 15:52:55 +0000
the Chart Values for Tools window is stuck
View Count: 1067
[2021-01-12 13:09:20]
shy - Posts: 35
TransAct DOM is working fine
Chart Prices are working fine
JUST the Window is stuck.
How do I free it?
[2021-01-12 15:26:19]
John - SC Support - Posts: 48419
When you select the X in the upper right corner to close the Tool Values Window, it will not close? Or do you not have access to the X for some reason?
If you can attach a screenshot, that would be helpful.
[2021-01-12 17:31:27]
shy - Posts: 35
I can close the window - this is not the problem!
the problem is that THE DATA in the window is not updating. it froze... it stuck (the data)
[2021-01-12 17:40:15]
One of two things is happening:
1. You have open the Chart Values Window and not the Tool Values Window. They are very similar, but the Chart Values Window only shows the information for the most recent bar, whereas the Tool Values Window displays the information for where the crosshair is located. Refer to the information starting here and the item after it:
Window, CB and CW Menus: Chart Values Window (Window)
2. The Tool Values Window is open, but you do not have the crosshairs activated, or another tool. If the selected tool is Pointer, then the Tool Values Window will not update as the pointer is moved.
Date Time Of Last Edit: 2021-01-13 18:00:57
[2021-01-12 20:19:14]
shy - Posts: 35
we are geting closer...
I did open the Tool Values Window.
How do I activate the crosshairs activated or any other tool?
(On my chart are currently 2 MA's and ATR...)
[2021-01-12 21:42:41]
Select Tools >> Chart Values/Crosshair.
Then make sure that the Tool Values Window is open.
Then left-click in the chart to bring up the Crosshairs, and as you move the mouse, the information in the Tool Values Window will change, based on the current position of the crosshairs.
[2021-01-13 05:24:43]
shy - Posts: 35
TNX
HALELUYA!
