Date/Time: Thu, 02 May 2024 02:18:55 +0000
Previous version does not work
View Count: 372
[2021-01-11 16:37:03] |
User723938 - Posts: 2 |
Hi, I want to work on Sierra v2150 but it deos not connect me to data feed. I get this message: Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-01-11 15:55:25.704 *. After I update to version 2215 I can connect,but all my addins don't work so I want to go back. Regards, Pawel |
[2021-01-11 16:40:06] |
Since you are using CQG you need to be on a current version. Older versions are no longer supported. You need to rebuild the custom studies for the current versions. Instructions: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-11 16:41:21
