Date/Time: Wed, 04 Nov 2026 15:52:54 +0000
4 hour bar close is different to other platforms
View Count: 820
| [2021-01-11 15:29:25] |
| User56075 - Posts: 4 |
Hi on sierra chart my 4 hour bars close one hour before the 4 hour bars close on my MT4 and Trading view platforms. How can I change it so that it is synchronised? Thanks Absar |
| [2021-01-11 15:32:45] |
| [2021-01-11 16:30:43] |
Refer to: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
