Date/Time: Wed, 04 Nov 2026 15:52:56 +0000
trading dome problem
View Count: 812
| [2021-01-11 14:43:02] |
| User698950 - Posts: 4 |
MY DPL is no longer accurate> I am trading for real so this should be accurate. It was for the first three weeks. please advise Chuck
| [2021-01-11 15:20:49] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-11 19:33:44] |
what you suggested was indeed not enabled so I enabled it. since I already had some trades and the DPL was a mess, I assume it should be fine tomorrow when we start from scratch. Thanks and I will let you know. I really appreciate the help Chuck T |
| [2021-01-13 14:03:35] |
I tried the dome yesterday but the problem persisted. might you have another suggestion. I tried again at the help manual but being almost 76 and having brain 0problems I can figure out what to do. Please help. Thanks Chuch T |
