Date/Time: Fri, 03 May 2024 01:42:30 +0000
Question RE: attached orders functionality
View Count: 521
[2021-01-10 17:46:19] |
Nick_ON_CAD - Posts: 20 |
Question: Is it supported to automatically bracket a new position IF you started the position by doubling the stop order size of an initial position? My current workflow: Double stop size to effectively reverse when stop hit. Result = a new position in opposite direction - but without a new stop/target bracket - so a naked position. I currently use "Send attached orders - position" to protect the new position and wondering if there is a way to eliminate this step. I don't use the reverse function because, in certain cases, I only want to reverse if stop hit. I have researched this extensively and just wondering if I'm not seeing the setting that would provide this functionality, or if I am doing it the best way. Thank you so much for your time. |
[2021-01-12 17:21:25] |
Refer to the updated instructions here to reverse on stop: Attached Orders: Reversing on Stop Attached Order You need to submit a new Stop order for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-12 17:38:07
