Date/Time: Fri, 03 May 2024 12:02:42 +0000
CPP custom study source file not found
View Count: 419
[2021-01-09 20:36:48] |
BenjFlame - Posts: 305 |
Hi, since newer version of Sierra requires to rebuild custom study, I went to rebuild mine, but the CPP file is not found. The dll is in the data directory, but the cpp file is not in its directory so I can't rebuild. "Source file "C:\SierraChart\ACS_Source\StocksRiskManagement.cpp" is missing." I never deleted this cpp file so not sure why it's not there. Is there a way to rebuild from the dll? Date Time Of Last Edit: 2021-01-09 20:40:27
[2021-01-10 07:33:50] |
You definitely need the original source code. You need to look around your system for it.
