Date/Time: Sat, 27 Apr 2024 14:45:26 +0000
Version: 2150
View Count: 430
[2021-01-08 21:02:42] |
Tomasz Sosna - Posts: 1 |
I warmly welcome, I have been obligated to install a version greater than 2150 because it will no longer be supported. However, the software I have for Sierra is compatible with this version of Sierra. Is this a definitive departure from this version? |
[2021-01-09 03:42:56] |
If you are using Sierra Chart with CQG there is a required update. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-09 03:43:08
