Date/Time: Sat, 04 May 2024 01:49:09 +0000
Add Additional Symbol - 90 day limit?
View Count: 459
[2021-01-08 18:38:07] |
User804559 - Posts: 22 |
Can I load more than 90 days of historical data with the "Add Additional Symbol" study? I have a historical volume based chart that goes back 1 year but when I load another symbol using the Add Additional Symbol study it goes back only 90 days. Why is there such a limitation? |
[2021-01-12 17:15:25] |
Provide us that chart containing the Add Additional Symbol study following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart And open a separate chart for the symbol you are using with the Add Additional Symbol study and then go to Chart >> Chart Settings. What is Date Range in File>> From set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-12 17:16:22
