Date/Time: Fri, 03 May 2024 21:10:32 +0000
previous version number
View Count: 574
[2021-01-08 15:41:02] |
User283059 - Posts: 3 |
can you give me a list of previous version number to the latest one 2215 ? |
[2021-01-08 16:16:13] |
Sierra_Chart Engineering - Posts: 14205 |
You can install any version you want. Instructions: Software Download: Software Rollback Procedure The prior version would be 2214. All version numbers are used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
