Date/Time: Sun, 28 Apr 2024 10:51:49 +0000
Status Bar
View Count: 414
[2021-01-08 14:11:24] |
DblArrow - Posts: 10 |
Is there any way to display the status bar outside of a control bar?
[2021-01-08 16:21:57] |
Sierra_Chart Engineering - Posts: 14111 |
Not exactly. However, you do have the ability to use any of the available 8 control bars and one of them could contain just the Status Bar display and can be set to be floating: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-08 16:22:09
