Date/Time: Sat, 04 May 2024 03:41:04 +0000
treausry data delayed
View Count: 473
[2021-01-08 12:23:32] |
User819363 - Posts: 1 |
Hi I have just opened a sierra chart account with AMP futures, and using your Denali feed. On ES is everything ok, but data on treasury ZB are delayed. Is it ok? what should I do to enable real time on treasury? thanks Andrea |
[2021-01-08 16:19:58] |
Sierra_Chart Engineering - Posts: 14207 |
This is on the CBOT exchange which you do not have active. So you need to activate the exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
