Date/Time: Fri, 03 May 2024 19:54:15 +0000
Market Depth Question for Stock and Barchart Data to plot Market Depth on chart.
View Count: 582
[2021-01-07 14:00:50] |
GravisHTG - Posts: 303 |
I know that they does not support Market depth but at least they have the Immediate Bid Ask. So we can plot the most recent bid ask on the chart. My question Is it possible to plot only Big walls or Big amount base on a % instead of a certain amount because i am trading multiple stock on the same settings. thanks |
[2021-01-07 16:44:33] |
We are not understanding the question.
[2021-01-08 04:23:46] |
my questtion is that with the market depth indicator. I will see the current Depth only. But Is it possible to plot it only when its a define % higher than normal. Or the only option we have is to put a certain static number. Another thing is, when are you planning to get Market depth for stocks ? And what about the option market. Thanks. |
[2021-01-11 15:20:18] |
John - SC Support - Posts: 31360 |
Which Market Depth indicator are you referring to?
[2021-01-11 16:14:51] |
Another thing is, when are you planning to get Market depth for stocks ? Regarding the Market Depth Historical Graph study, this is the case: Or the only option we have is to put a certain static number. Refer to:Market Depth Historical Graph: Study Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-11 16:15:52
[2021-01-27 06:31:23] |
pnlcheck1 - Posts: 6 |
What is the eta for Market Depth for stocks? And will all data feeds that have this data be supported? |
