Date/Time: Mon, 29 Apr 2024 07:01:18 +0000
Replay issue with studies using pulling/stacking data
View Count: 739
[2021-01-06 18:04:44] |
mattvk - Posts: 32 |
I'm running SC 2215 with the Denali feed. "Support downloading historical market depth data" is set to YES. When running a replay, certain studies which use pulling/stacking data are not updating or displaying any data. "Numbers Bars Calculated Values 2" / "Ask/Bid Pull/Stack Sum Diff" not receiving data and showing zero for all columns on playback, while real-time is functioning as intended. I have confirmed that historical data is present by initiating "Download depth data from date-time" and using the "Market depth historical graph" study. Please advise, thanks. |
[2021-01-13 04:28:25] |
We are not able to reproduce this problem. Refer to: http://www.sierrachart.com/image.php?Image=161051202539.png The pulling and stacking data is replaying fine even when using the Sierra Chart Order Routing Service symbols and data formatting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-13 04:28:57
