Date/Time: Sat, 04 May 2024 00:56:15 +0000
Question about singles and how to get them to match TPO chart, on MP chart
View Count: 586
[2021-01-07 03:43:01] |
We require a paid account for technical support. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-07 03:43:15
[2021-01-10 05:06:10] |
Ok we cannot see that paid account. Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program. Question is .... how do I get a "valley" line to appear in the volume chart (Monitor Two) as a "single" so that it matches the same 'single' number in in TPO chart (Monitor One) The Peak and Valley line functionality for Volume Profiles does not match the "singles" functionality for TPO profiles. So what you want is not possible.and have a horizontal line in volume chart that extends until further intersection???????
Peak and Valley lines do support extension until future intersection. Are you having an issue with this?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-10 05:06:30
