Date/Time: Wed, 04 Nov 2026 16:06:26 +0000
TPO chart display bug - Open, Low, and structure are incorrect
View Count: 844
| [2021-01-06 14:41:54] |
| User641030 - Posts: 13 |
The TPO structure is formed incorrectly. The Open and low in particular is wrong. The C and D periods in the Jan 15 profile does not go below the A period's low. I have never seen this before. If you need my chart settings, please let me know. http://www.sierrachart.com/image.php?Image=1609943812325.png Thanks Hari |
| [2021-01-06 14:56:04] |
| John - SC Support - Posts: 48419 |
You need to change your Evening Session End time to 06:29:59. Refer to the information here: Chart Session Times: Evening End Time (Chart >> Chart Settings >> Session Times) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
