Date/Time: Wed, 04 Nov 2026 16:06:27 +0000
two devices are not displaying simelatneous data
View Count: 787
| [2021-01-06 04:00:46] |
| teamjream - Posts: 1 |
Hello, I have two devices running SC, but only one of them is getting real time data. In order to update the current tick on the other device, I have to press "edit --> download data from end of chart". I have read everywhere on the website I am able to have two devices running the same connection, but it does not seem to work. Any help would be appreciated. Thank you |
| [2021-01-06 04:22:27] |
Refer to this section here in regards to this, if you are referring to real-time futures data from the Denali Exchange Data Feed: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
