Date/Time: Wed, 04 Nov 2026 16:06:27 +0000
studies not working
View Count: 931
| [2021-01-05 18:07:07] |
| mapan123 - Posts: 10 |
hello, I have a problem with my studies if I can get some help to understand why it does that. For ex- my bollinger bands on one chart just disappear and a few other study are not showing. they worked in the morning and then were not there anymore. I did try to reload the charts many times and still the same. some help will be appreciated. Thank you |
| [2021-01-05 18:26:04] |
| John - SC Support - Posts: 48419 |
What Region and Scale are your Bollinger Bands set to?
| [2021-01-05 18:41:08] |
I have it on region 1 and scale automatic
| [2021-01-05 18:45:07] |
the thing is they worked fine so far but today they are not showing on the chart, and I haven't done anything, I also updated to the newest version, delete and download the data and still nothing |
| [2021-01-05 19:43:05] |
Attach your Chartbook to this thread for us to take a look. Refer to the following information for how to attach a chartbook with just the one chart showing the problem: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-05 21:16:22] |
File attached
Attachment Deleted. |
| [2021-01-05 21:18:21] |
so the problem is with bollinger bands and the opening range study and all the other charts in this chartbook which most have the same setups work |
| [2021-01-05 21:21:57] |
We first want you to read through this section to see if you can determine what the problem is: Chart Studies: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-05 21:22:03
| [2021-01-05 22:57:15] |
it looks like the problem was that i deleted the chart that i was overlaying the study from. works now. Thanks for the help
