Date/Time: Sun, 28 Apr 2024 20:14:30 +0000
DOM Constant Scale Range
View Count: 576
[2021-01-05 16:03:12] |
User907968 - Posts: 802 |
Hi, Since a recent version, not sure which, each time SC is restarted, the DOM constant range setting is reset (instead of respecting custom setting). Is this by design or have I mistakenly changed some setting, as it certainly didn't used to behave this way? Thanks edit: Currently using version 2215 Date Time Of Last Edit: 2021-01-05 16:58:14
[2021-01-05 19:43:21] |
We see why this happens. We will resolve this in the next revision coming out today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-05 19:43:28
[2021-01-11 14:08:40] |
Hi, this appears to be resolved in v2218, however double-click to re-center is now not working for DOM.
Date Time Of Last Edit: 2021-01-11 14:08:58
[2021-01-11 19:39:44] |
Oh yes that is true. Double clicks are not interpreted on a Trading DOM so that users can use a double-click to enter two orders.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-11 19:40:01
[2021-01-11 19:54:52] |
Ok, I see, that is rather inconvenient, if I'm being honest. I do have a keyboard shortcut setup to re-center DOMs, but that is not always the quickest way. EDIT: Ok, no longer an issue, have autohotkey workaround. Date Time Of Last Edit: 2021-01-11 22:01:30
