Date/Time: Wed, 04 Nov 2026 16:19:03 +0000
Order Routing Servers
View Count: 858
| [2020-12-30 11:02:55] |
| tobi - Posts: 351 |
Residing in Germany, which servers (https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions) would you recommend as primary, 1st and 2nd backup?
| [2020-12-30 20:58:54] |
What exchanges are you trading on?
| [2020-12-30 21:23:57] |
| tobi - Posts: 351 |
CME
| [2020-12-30 23:27:39] |
In this case use the servers in this order: Server 1 Server 2 Server 4 There is no reason to use a server in Europe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
