Date/Time: Thu, 02 May 2024 04:24:55 +0000
Change cursor color
View Count: 2312
[2014-02-19 13:30:19] |
stab567 - Posts: 2 |
Hello, 1)Is there a way to change the cursor color from white to any other color? 2)Can I move the chart tab from the top of the chart to the bottom only? 3)Can I edit the Tools Value Window to just show the High & Low of a bar? Thank you |
[2014-02-19 15:51:49] |
Sierra Chart - Max - Posts: 5598 |
1. Refer to the steps here: http://www.sevenforums.com/tutorials/2402-mouse-pointers-change.html 2. Go to Global Settings >> General Settings >> General 2 >> Tabs, and set Place MDI Tabs At to Bottom. 3. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#CustomizingToolValuesWindows Sierra Chart Support |
