Date/Time: Wed, 04 Nov 2026 16:32:03 +0000
Setting global download date range
View Count: 865
| [2020-12-26 19:18:26] |
| HeyUgly - Posts: 287 |
hello i trade different stocks daily, I have a nice history chart on daily but it always defaults to 2020 Jan 1, i want it to automatically download 3 years of history, is there a global download data date set i can setup, because i have to chage it everytime i bring up a stocks hhistory thanks in advance, and thanks for the great support on the site! i wish you could could link with tradezero for small cap guys who love your charting platform |
| [2020-12-28 16:58:33] |
| John - SC Support - Posts: 48419 |
If you are bring up a Daily historical chart, then it should automatically download all of the available data. It sounds like you may be using Intraday data, in which case refer to the settings here: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-28 21:43:44] |
All available Historical Daily data is always downloaded for Historical charts. There is no way to change this. Also refer to: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-28 21:44:02
