Date/Time: Wed, 04 Nov 2026 16:19:07 +0000
NumberBars Color
View Count: 851
| [2020-12-26 10:26:13] |
| Zazza.83 - Posts: 11 |
It is possible to have the calculation for the coloring of the numberbars Determine Maximum / minumim Values for coloring Form (in: 15) Not only Bar Data and Daily Data, but also the possibility to indicate a number of pre-defined bars Ex. Last 30 Bars or 50 Bars Thanks and happy holidays to all |
| [2020-12-26 18:14:26] |
And if possible have the color of the numberbars askvol bidvol difference not only actual but also percentage thank you for your continued support and professionalism
| [2020-12-28 16:05:12] |
| John - SC Support - Posts: 48419 |
With regards to Post #1, we cannot make any guarantees of a change like this happening anytime soon. With regards to Post #2, refer to the following background coloring and see if this will work for you: Numbers Bars: Background Coloring Based on AskVol BidVol Difference Percentage of Max Dominant Side If not, then let us know what exact calculation you are looking for and we will see if we can add it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-28 18:15:11] |
Basically what I am looking for is being able to define through number bars how a specific horizontal delta/ bid ask difference is relevant in terms of relativeness; for example a bid ask difference of -100 lots on es can be nothing during rth but could be quite relevant during eth, that's why it would be very useful having an additional function to be comparing the delta for each price in a specific previous period, and then picking the range for background coloring based on that percentage of volume. Example: in the previous ten bars or minutes the highest value of horizontal delta has been 100, the currently traded price has a delta of 75', therefore it falls under the range 3 up for background coloring, assuming it is set to 0.25, 0.50, 0.75 |
| [2020-12-30 19:20:45] |
| User181185 - Posts: 1 |
That would be a great add! I use Ask vol/bid vol percentage on daily data but that's about ask and bid values not the difference
