Date/Time: Sun, 19 May 2024 14:30:10 +0000
Charts to Replay
View Count: 539
[2020-12-25 15:08:06] |
User377189 - Posts: 154 |
I have couple of charts in my chartbook. Some are RTH and other ETH I select replay chart control from RTH chart and select the following within the replay control: Charts to Replay: all charts in chartbook Replay mode: Standard Use Start Date-Time: This is selected as i want the chart to replay a specific day and time i select is 09:26:00 The time gives me view 4minutes before ES open The ETH charts show price movement but when 09:30:00 i.e. open ETH charts continue to replay but RTH charts are static and do not show price movement at all Another thing i noticed when i change time for replay to 09:31:00 All charts are synced but when i click pause in the Replay chart control all charts pause, but when i am ready to continue my replay session and hit play the chart does not start where i left off it jumps to 15-20 minutes forward. |
[2020-12-28 15:13:59] |
John - SC Support - Posts: 31721 |
Most likely, it is what is described here (also refer to the section above it for more information): https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#PreventingLossOfSynchronizationBetweenDifferentChartsDuringReplay For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-28 21:42:36] |
We will see if we can reproduce any of these issues. We are quite busy now, so allow us about a week or so to look into this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-28 21:42:47
