Date/Time: Mon, 29 Apr 2024 05:01:47 +0000
[Programming Help] - Why are the downloadable DTC files different from what is in the installation directory?
View Count: 634
[2020-12-24 22:12:53] |
RoadKill - Posts: 38 |
Hi, I'm building a python tool to interact with SC using the DTC protocol. However, I just noticed that SC is linking to a different set of DTC files than what come with the SC client in the ../DTC/ directory. # From SC DTC directory 291K Dec 22 12:10 DTCProtocol.cpp 119K Dec 22 12:10 DTCProtocol.h 45K Dec 22 12:10 DTCProtocol.proto 56K Dec 22 12:10 DTCProtocol_NonStandard.cpp 56K Dec 22 12:10 DTCProtocol_NonStandard.h 99K Dec 22 12:10 DTCProtocolVLS.cpp 91K Dec 22 12:10 DTCProtocolVLS.h # Downloaded DTC files from [1] 267K Dec 24 03:48 DTCProtocol.cpp 109K Dec 24 03:48 DTCProtocol.h 41K Dec 24 03:48 DTCProtocol.proto 92K Dec 24 03:48 DTCProtocolVLS.cpp 84K Dec 24 03:48 DTCProtocolVLS.h [1] https://dtcprotocol.org/DTC_Files/ 1. Why are these different? 2. Which ones should/can I rely upon? 3. What are their respective functions? 4. Is this the correct forum to post questions like this, or should I use [1]? Thanks in advance. & Merry X-mas. Date Time Of Last Edit: 2020-12-24 22:15:57
[2020-12-26 15:48:45] |
bradh - Posts: 854 |
I cannot help you on this, it is beyond my skill set. However, you may find more people who can help you on the DTC Protocol Support Board: https://dtcprotocol.org/SupportBoard.php
[2021-01-04 20:12:51] |
This is the https://dtcprotocol.org/SupportBoard.php ! I'm confused, where can I find help? |
[2021-01-05 15:32:52] |
I'm confused, where can I find help? That is interesting. I am reading it on the Sierra Chart board. It appears this message thread appears in both forums. Perhaps when you put [Programming Help] and DTC in the subject line, it got routed to both? The lists of messages are definitely not identical. |
[2021-01-17 10:53:25] |
Any updates or insight on this?
