Date/Time: Sun, 19 May 2024 13:52:11 +0000
TPO profiles - custom intraday session colors
View Count: 644
[2020-12-23 10:02:28] |
User365411 - Posts: 178 |
I was already asking for a color differentiation for each custom intraday session, I don't know if you read that message and it's already in your todo list. TPO profiles - fundamental missing features | Post: 238827 Anyway I noticed that this task can be accomplished easily with the "TPO Letter/Block Colors (ln:17) - Use Letter/Block Color 1-18 for Periods". But there is a problem, given that there are 18 colors, setting same 3 different colors for 6 times it works but only if there are 3 sessions, obviously if there are 4 or 5 sessions the profiles colors lost the correct sequence. It's possible to add an option to tell SC to use and repeat only the first 3/4/5 colors so it use the right color sequence in 3/4/5 custom intraday sessions ? TY Date Time Of Last Edit: 2020-12-23 16:03:46
[2020-12-26 07:47:26] |
We will look into this.
