Date/Time: Wed, 04 Nov 2026 16:39:28 +0000
Problems with my chartbook
View Count: 860
[2020-12-23 07:41:19]
g4500 - Posts: 27
Hi
Since 2 months i have an problem my chartbook.
Every 2 / 3 weeks of use , the chartbook stay freezed. It don t load the charts and block all the Sierra program.
The chartbook since this moment is not useful anymore
I have to create another one but it s quite anoying cause i need set up all the time the new one.
Can you help me with that ? and what are the cause?
imageCaptura de pantalla 2020-12-23 a las 8.32.28.png / V - Attached On 2020-12-23 07:41:00 UTC - Size: 507.89 KB - 345 views
[2020-12-23 15:14:03]
John - SC Support - Posts: 48419
Refer to the information here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
[2020-12-23 19:29:22]
We want you to provide that Chartbook by following these instructions here:
