Date/Time: Wed, 04 Nov 2026 16:38:35 +0000
Import Chart Settings
View Count: 1634
| [2020-12-23 03:49:52] |
| Ethan Busenitz - Posts: 1 |
i am trying to import sierra chart settings from my colleague. i successfully got them up and running with all the settings except there is no chart being displayed.
| [2020-12-23 04:20:05] |
If you have opened a Chartbook and the charts are blank, the symbols may not match the selected service you are using. In this case you need to translate the symbols with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
