Date/Time: Wed, 04 Nov 2026 16:39:35 +0000
Global crosshairs not working across all charts
View Count: 1548
[2020-12-22 04:25:41]
User148596 - Posts: 217
My numbers bar chart doesn't seem to want to recognize the global crosshairs. It works in reverse, as in, if I have the crosshairs on the numbers bar chart it shows up on other charts, but not the other way around. I was trying to see what the numbers bars were showing at a particular point in time on a separate chart and couldn't get the numbers bars timeline to change at all.
The chart settings are the same as far as contract settings.
[2020-12-22 05:47:08]
Is the Numbers bars chart, showing the same Date-Time and price as the source chart which you are using the Chart Values tool on?
[2020-12-22 05:56:01]
Refer to the documentation here for this feature:
Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
It has all the information you need.
