Date/Time: Wed, 08 May 2024 05:49:35 +0000
Snap lines to indicator subgraphs
View Count: 1487
[2014-02-18 15:57:35] |
cazeek - Posts: 33 |
Hello, I want to be able to snap an extended line to the RSI line in the subgraph. Whenever I try to snap, it just snaps to one of the horizontal lines (at 70 and 30). How can I direct it to snap to the RSI (or any other indicator like this). Thanks, Steven |
[2014-02-18 18:49:26] |
What is the exact command you are using to perform the snap? Try using Snap to Open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-18 18:50:48] |
that did it- never tried snap to open before- thanks!
