Date/Time: Tue, 21 May 2024 17:21:50 +0000
[User Discussion] - SPREADSHEET CONSECUTIVE LOSRS & CONSECUTIVE WINNERS
View Count: 879
[2020-12-17 00:56:13] |
User355030 - Posts: 163 |
Is there a way to access CONSECUTIVE LOSRS & CONSECUTIVE WINNERS in the spreadsheet? @SCE
[2020-12-17 07:00:48] |
No this is not supported.
[2020-12-17 15:07:39] |
on the road map? @SCE
[2020-12-17 15:08:05] |
@tomgilb anyway to creatively calculate this?
[2020-12-17 21:27:29] |
Sawtooth - Posts: 4002 |
It is possible to count consecutive winners and losers in two formula columns, after adding the Trading: Winning Trades and Trading: Losing Trades studies. Here's an example of how: https://www.sawtoothtrade.com/example-1.html You could then find the max for each per period, or the consecutive count of each per period. How to do the latter would be more than could reasonably be shared in a forum post. Contact me here if you want to pursue this: https://www.sawtoothtrade.com/contact.html |
