Date/Time: Mon, 06 May 2024 18:53:34 +0000
Had to reinstall Sierra Charts
View Count: 1060
[2014-02-18 01:55:02] |
tom85308 - Posts: 23 |
I had to reinstall Sierra Charts. Once I did and logged in I have many missing charts. How do I get them back?
[2014-02-18 03:24:43] |
This is not completely clear to us. Are you missing your Chartbooks? Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails22.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-18 04:32:02] |
Yes they are missing however I am in the process of recreating them. Could the problem be attributed to me previously using version 964? I could not upgrade after that so I had to use an old version. I just cleaned my computers and switched anti virus software so I am using version 1091 now. My heading reads "sierra chart 1091 daily charts.cht transact date time sim". What does the sim mean?
[2014-02-18 15:25:56] |
Sierra Chart - Max - Posts: 5607 |
Regarding SIM, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_TradeSimulation.php#Intro Sierra Chart Support |
[2014-02-18 17:15:12] |
Could the problem be attributed to me previously using version 964? No, this was not the problem.
