Date/Time: Sun, 05 May 2024 20:52:50 +0000
[User Discussion] - Countdown Timer
View Count: 1377
[2014-02-17 20:49:22] |
jayaaron1 - Posts: 2 |
Understand I am a complete code writing moron, so don't rip me up too bad. I know the bar countdown timer in Studies can be set to alarm on bar on new bar. Is it possible to set it up to alarm before bar close? For example, assume watching a 5 minute bar. Can the the countdown timer be setup to alert at 4 minutes, one minute prior to bar close? So, that on every 5 minute bar, the countdown timer is alerting one minute before the close of that bar. Thanks much for your time. Date Time Of Last Edit: 2014-02-17 20:50:14
[2014-02-17 21:24:48] |
Sawtooth - Posts: 3993 |
Have a look at this: http://www.sawtoothtrade.com/free-stuff-11.html Date Time Of Last Edit: 2015-08-14 01:55:31
[2014-02-18 18:52:05] |
Yes. But this will require programming changes. We do not provide programming help, but maybe someone here on the board could help.
