Date/Time: Sun, 28 Apr 2024 19:24:57 +0000
[Programming Help] - update symbol settings
View Count: 407
[2020-12-04 09:55:10] |
User482964 - Posts: 5 |
Hi, i get message for update to continue to have access to symbol settings. when i go to download current current version got message installer program has been downloaded. press yes or no action stops.. what do i have to do (i am a new user) regards arvin |
[2020-12-04 19:11:42] |
Update Sierra Chart from this page: Software Download Make sure Sierra Chart is not running when you are updating it. There is also a ZIP installer available: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-04 19:11:51
