Date/Time: Sat, 04 May 2024 07:13:12 +0000
CQG Credentials
View Count: 477
[2020-12-03 19:08:47] |
User822445 - Posts: 65 |
Hello there, I just opened an account with Ironbeam and I also got my CQG Credentials (Username + Password) to begin trading. When I go to Data/Trade Service Settings, do I need to select "CQG FIX Trading" or "CQG WebAPI" in order to log in? From what I see, "CQG FIX Trading" do not appear in the selections. Regards, Alexandre |
[2020-12-03 19:45:01] |
You can only use the CQG Web API. That is all that is available now. Refer to: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
