Date/Time: Mon, 29 Apr 2024 07:26:13 +0000
HKEx
View Count: 970
[2020-12-03 15:19:07] |
User608009 - Posts: 3 |
Hello! I have activated HKEx , but could find only Hang Seng and Mini. Is it possible to trade HKEx with APM through SC order routing?
[2020-12-03 19:25:30] |
Is it possible to trade HKEx with APM through SC order routing? We need to check on this.
[2020-12-07 13:29:38] |
So before I had affiliated with AMP Sierra Charts fed by Denali. I have added HKEx data recently, but I have no any idea how to execute
[2020-12-07 21:09:59] |
Sierra Chart does support trading the Hong Kong exchange on the Sierra Chart Order Routing Service but we are not sure if your broker AMP supports this. You can try to submit an order. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will find the symbols in File >> Find Symbol >> Futures-HKFE. There only two symbols listed but we can add other Hong Kong exchange products. Just let us know what you want to trade but first see if it is even possible to trade them. Would be best to contact your broker first about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-08 07:57:59] |
AMP staff replied : "Hello HKEX is only available with CQG not Denali." But I didnt mention about Denali when I asked them.... Anyway, it would be good to add following HKEx contracts: -CUS (USD/CNH) -GDR (CNH Gold -HB3 (3-month HK Interbank Offered Rate) -HHI (H-shares Ind) -HTI (Hang Seng Tech Ind) -HSI and MHI (Hang Seng and Mini Hang Seng) -MCH Mini H-shares |
[2021-11-03 13:42:15] |
daniel.lee - Posts: 3 |
Hi SC team, Would you mind adding HTI (Hang Seng Tech Ind) as well? thanks |
