Date/Time: Mon, 06 May 2024 00:00:11 +0000
Promlems installing software
View Count: 526
[2020-12-03 11:30:13] |
Six Five - Posts: 5 |
Hello, I have downloaded the latest version of Sierra Chart via your link, but when I try to install it (the .exe file ) I get a message saying " the contents cannot be extracted with the unarchiver" Im using MOCos Sierra version 10.12.6 how can I solve this problem. Thanks |
[2020-12-04 02:14:45] |
That error message makes no sense. There are no files extracted with our standard installer. Use this link: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe If you still have a problem, try the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
