Date/Time: Tue, 07 May 2024 21:57:34 +0000
Numbers Bars Calculated Values 2 study
View Count: 723
[2020-12-03 05:19:20] |
User912281 - Posts: 18 |
For the "Numbers Bars Calculated Values 2" Study, is it possible to specify the number of decimal points for the subgraph entitled "Ask Volume Bid Volume Difference Per Tick"? Depending on the symbol, as many as 7 decimal points are displayed. It would be preferred to present the data to a maximum of only one decimal point. Thank you in advance for your assistance! |
[2020-12-03 07:26:20] |
We will look into this.
[2020-12-03 22:38:01] |
John - SC Support - Posts: 31441 |
We will change the Input for Use Default Formatting for Percentages to be Use Default Formatting for All Subgraphs. This will then override the special formatting that is in place for all items that use a special formatting, like the Ask Volume Bid Volume Difference per Tick, and will use the Value Format that is set for the study itself instead. We will let you know when we have this completed in a day or two. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-04 18:32:03] |
We have made this change, so it will be in the next Pre-Release (v 2207). The new setting will change all items that have special formatting to use the formatting set for the study when it is set to Yes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
