Date/Time: Wed, 08 May 2024 03:20:46 +0000
Need to have GAIN Capital/OEC enabled.
View Count: 402
[2020-12-02 20:13:14] |
User721807 - Posts: 1 |
I have Service Package "3-Standard(Monthly)" on my sierra charts account details enabled. But it only shows "GAIN Capital/OEC (Not enabled on package)" , not enabled on package. Do I need a different service package type or have something setup with the broker? |
gain_not_enabled_on_package.JPG / V - Attached On 2020-12-02 20:13:00 UTC - Size: 433.28 KB - 209 views |
[2020-12-03 11:38:18] |
Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
