Date/Time: Wed, 04 Nov 2026 17:05:28 +0000
Rithmic
View Count: 949
| [2020-12-02 15:49:03] |
| Nicogou21 - Posts: 12 |
Greetings, I have heard that as of January 2021, it will no longer be possible to use rithmic as means to get a flow from the market. Could you please confirm this point? Best Regards, Nicolas |
| [2020-12-02 18:14:04] |
There are no changes planned with Rithmic in January 2021.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-02 18:14:56
| [2020-12-02 18:17:16] |
Hello, Any changes for the year 2021? Will it still be possible to use rithmic and Sierra chart, the whole year, next year |
| [2020-12-03 18:28:07] |
This is up to Rithmic. Sierra Chart is an open platform, and they are working on integration using the DTC protocol. Although Rithmic will be fully responsible for the market data. We will not do anything to provide secondary market data including historical data unless you decide to use one of our data feeds: Real-Time Exchange Data Feeds Available From Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-03 18:28:25
