Date/Time: Fri, 03 May 2024 22:04:48 +0000
Discrepancy between stop offset parameter and resulting stop in chart trade
View Count: 411
[2020-12-02 15:25:46] |
Bertram The - Posts: 3 |
Hi, When using the DAX-202012-DTB-EUR-25 [M] future chart, the chosen stop loss offset in the trading window is always diminished by half. So, when using a simple bracket, the standard stop offset of 8 results in an offset of 4. I've added a picture of both the parameters (in this case a triggered step trail stop) with a chosen stop offset of 60, as well as the resulting orders in the chart: here you can see that the resulting offset is actually 30 points. How can I fix this discrepancy? Many thanks in advance! Mr. B. The |
Screenshot 2020-12-02 at 16.17.34.png / V - Attached On 2020-12-02 15:19:14 UTC - Size: 534.79 KB - 174 views |
[2020-12-02 16:04:54] |
John - SC Support - Posts: 31362 |
You are entering your offset in Ticks as specified by the Offset Value. Since the DAX has a tick size of 0.5, this results in a offset in points that is half the number of ticks. Refer to the information here for that setting: Attached Orders: Offset Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
