Date/Time: Thu, 02 May 2024 00:07:52 +0000
calibrate DOM
View Count: 449
[2020-12-02 15:17:26] |
User400065 - Posts: 4 |
Hello SC, My problem is that i want to increase the size of the price line and the size of the number but when i go to > graphics settinf > fonts > chart text , it increases only below the current price and it is not calibrate anymore. How do i do to just increase the polic size of all column ? I put a picture for you to understand. Thank you |
screenshot dom problem.PNG / V - Attached On 2020-12-02 15:14:31 UTC - Size: 62.65 KB - 210 views |
[2020-12-02 15:44:42] |
John - SC Support - Posts: 31293 |
The Price column font size is controlled by the Chart Text font and it changes all of the price values, not just the Current Price. If you do want to change this just for the Trading DOM, then on the Trading DOM select Chart >> Graphics Settings and then deselect the option for Use Global Graphics Settings Instead of These Settings then go to the Fonts tab and select the Chart Text. Then change the font as desired and it will update just for the Trading DOM, of which the primary change will be to the price ladder. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
