Date/Time: Mon, 06 May 2024 12:44:34 +0000
Different price in different TF
View Count: 471
[2020-12-02 15:01:55] |
User82995 - Posts: 15 |
IN 1 min chart show me a price but in 15min TF shows another price. Why? I have the problem with other symbols too. |
sierrachart1.png / V - Attached On 2020-12-02 14:59:45 UTC - Size: 288.62 KB - 175 views |
[2020-12-03 11:25:16] |
We are not really sure why that would be the case. Do you notice this just sometimes? What happens if you wait a few seconds more. Is the last trade price then the same? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-03 11:25:25
[2020-12-03 14:59:06] |
This occurs in some stocks, in some cases the difference its big and the others its very subtle. This happens more from the open session 9h30 am market time. This stocks are from today from the picture.
sierrachart4.png / V - Attached On 2020-12-03 14:57:00 UTC - Size: 189.93 KB - 152 views sierrachart3.png / V - Attached On 2020-12-03 14:57:08 UTC - Size: 344.88 KB - 158 views |
[2020-12-03 16:23:52] |
Could be a internet connection problem?
[2020-12-03 19:31:03] |
Make sure all those charts are using a consistent Chart Update Interval of somewhere between 500 to 1000 milliseconds. Refer to: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
