Date/Time: Tue, 07 May 2024 18:40:29 +0000
Detached Window dissapears
View Count: 318
[2020-11-30 19:34:55] |
User327844 - Posts: 5 |
Hi, when I detached 2 of my charts they disappear and do not work, if I attach them again (through the keyboard shortcut) they will appear again in the chartbook. How can I solve this? I tried to "reload and recalculate", "Reset child window" and I relaunched sierra charts several times but nothing seems to work. Thank you |
[2020-11-30 20:09:30] |
John - SC Support - Posts: 31437 |
The thing to do is when the window is detached, open the Task Manager and find the appropriate window from the list under Sierra Chart, then right click on that window and select Maximize. You can then drag the window down and place it where you want.
