Date/Time: Mon, 29 Apr 2024 12:45:19 +0000
Chartbook list options
View Count: 520
[2020-11-30 07:35:25] |
User27542 - Posts: 20 |
I wondered if there is any way you can list all the open chartbooks without having to scroll. Particularly if you have a lot of chartbooks open, it can be a nuisance either to have to scroll in the CB tab or to scroll in the chartbook list just under the top toolbar. Any advice would be welcome. Thanks.
[2020-11-30 10:32:17] |
Have a look at Window >> Windows and Chartbooks: Window and CW Menus We would think the CB menu would list all of the Chartbooks without having to scroll unless you have a large amount open at once. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-30 11:01:54] |
I do have a fairly large number open at once (about 40-50). The problem with the CB tab is that all the open chartbooks are listed as a single column, which means that you have to scroll to reach ones at the bottom of the list. Is there any way for chartbooks to be listed in more than one column under the CB tab?
[2021-02-03 00:38:58] |
whats1thingnow - Posts: 407 |
i also have 40+ charts open for my chartbooks is there a way to export the name of all the charts? that way i can look through and sort through the names in an text editor or something i want to see my groupings of linked charts but haven't found a way to do it yet and i also want to show unused (unassigned/inactive) chart link numbers (show unused (unassigned/inactive) chart link number), but also haven't found a way anyone know of a way to get and export a list of all the chart names? |
