Date/Time: Sun, 28 Apr 2024 17:22:53 +0000
TPO chart missing choice to split profile
View Count: 544
[2020-11-29 23:29:06] |
User648702 - Posts: 48 |
When I right click on my tpo profile and the list comes up but is missing the choice Letters/Blocks In Own Column And Standard Profile. My list only has the choice Letters/Blocks In Own Column all profiles listed as a choice so I am unable to get the profile separated. I was going to send a capture of your instructions that show how to do this but don't understand the directions how to attach a simple capture.
TPO Split profile.png / V - Attached On 2020-11-29 23:03:42 UTC - Size: 94.67 KB - 162 views |
[2020-11-29 23:43:49] |
You need to update to the current version for those commands. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
