Date/Time: Mon, 29 Apr 2024 13:31:34 +0000
Continuous futures contract constructed differently between sub-instances
View Count: 389
[2020-11-29 02:42:26] |
jwick - Posts: 142 |
I'm noticing that between my parent and my sub-instance, my continuous contract is constructed differently. In the attached screenshot, the same chartbook (so the chart setting is identical) shows different data when moved prior to the current front month (if I scroll it forward to dates within the current front month, the data is the same). In this case both are using date rule rollover back adjusted. Any advice? Edit solution: I'm not sure why my sub-instance data was out of sync (which is unfortunate since I was testing off that data). Deleting it on my sub-instance caused it to back adjust using the same offsets from my main instance. Date Time Of Last Edit: 2020-11-29 02:54:05
Private File |
